Startseite · Forum · CAN Module · Shops · Katalog · Pressearchiv · Downloads · Videos · WebLinksSamstag, 19. April 2025
Autor Gleisreporter Switches Weichenchef   1 # 4 top
Fredde
Eingetreten: 14.03.14
Eingetragen am 09.10.2014 14:11
hi
Have a wonder.
Have installed 5 Gleisreporter and 5 Weichenchef.
In the beginning I did not understand how I could learn Weichenchef to get the right module no.
With some tweaking spirit, I managed to finally solve the problem.
But when Blocks 3 or 4 are occupied, switch (WeichenChef Module 3 Output 1 (0009)) switches.
Eventually, I changed so Gleisreporter (Module 1) does not exist, so they start with Module 2 instead.
But to make this work, I was forced, not to use Block No. 0001-0008.
What could I have done wrong in the beginning, so I got this problem?
Autor RE: Gleisreporter Switches Weichenchef   2 # 4 top
Eingetragen am 10.10.2014 13:54
Hej Hej Fredde,
first short question: do you have a "CC-Schnitte" and use the Softwaretool für the "WeichenChef"?
Greetings,
Autor RE: Gleisreporter Switches Weichenchef   3 # 4 top
Fredde
Eingetragen am 10.10.2014 20:33
Hej
Yes i have a CC-schnitte and Softwaretool.
Autor RE: Gleisreporter Switches Weichenchef   4 # 4 top
Eingetragen am 11.10.2014 14:07
Hi Fredde,
I’m sorry, because I don’t have translated the description of the new WeichenChef 2.1 Magnet (solenoid) yet.
The new WeichenChef 2.1 now has five instead of four addresses. The fifth address is for switching on and off an automation function. If the address is 'red' then the function is off.
If the fifth address is 'green' then the WeichenChef interprets a GleisReporter’s feedback that can effect switching on the four outputs of the WeichenChef. This way one can create a little automation on the layout without using a computer.
It is a bit complicated. I will try to explain everything in English so that you can choose if you like to use the function, but I still need a bit time for that.
As first attempt to solve the problem, please make sure that the fifth address of your WeichenChefs are switched to 'red'.
Kind regards,
